You might want to get all four injectors wired first before starting the motor... Starting fluid is close to gasoline in its combustion characteristic... So your starving the motor... Try wiring all injectors before starting it up...ducman said:
You might want to get all four injectors wired first before starting the motor... Starting fluid is close to gasoline in its combustion characteristic... So your starving the motor... Try wiring all injectors before starting it up...ducman said:hi, i bought a '83 celica gt with a toasted 22re motor that had been pulled from car. motor that came with car had spun a crank bearing so i bought a 22r motor and swapped on the efi to that block and put it in my car. the problem is the car will start and run for 2-7 seconds than quit. sometimes i can restart the car which will run for less time or not at all immediately following the first start. after waiting a minute or two the same senario will happen,start for aliitle than quit then maybe restart maybe not. if i sqirt starting fluid in the car it will run until i quit with the starting fluid. i have between 36 and 38 psi fuel pressure. i have firing signal to two of the four injectors(figured it should stay running on at least two cylinders if the other two are not firing). i have between 155 and 165 psi compression. i have replaced the timing chain, distributor cap and rotor, and sparkplugs. i have added new gas to the existing gas which may be old. does anyone think the motor will act like this on old gas or is there another problem?
thanks for any help.
