1 - 9 of 9 Posts
1-3-4-2
Can be verified by removing the spark plugs and seing that 1 & 3 are at TDC.Also see the service manuals below:
Any Public Library in your area would have the Factory service manual,Haynes,Chiltons,Mitchells,Clymers,Bentley and Toyota repair books.
There is also free AutoZone service manuals at:
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/repair_info/repair_guide/repair_guide.jsp
1985 Toyota 4-Runner/pickup Factory Service manual:
http://www.jasuza.com/1985toyotatruckfsm.pdf
1993 Toyota Pickup Service Manual:
http://personal.utulsa.edu/~nathan-buchanan/93fsm
2003 (2001-2004) Toyota Tacoma Factory Service Manual:
http://fsm.afraid.org/
http://www.junglecode.com/toyota/tacoma/2003_fsm
http://65.200.1.6/FSM/
FSM (factory service manual)can be acquired in several ways:
Toyota Material Distribution Center
750 West Victoria St
Rancho Dominguez/Compton,CA 90220-5538
USA
Ph:1-800-622-2033 (outside CA)(M-F: 7-5 PST)
Ph:1-800-443-7656 (inside CA)
Ph:1-310-818-4630 (in or outside CA)
Speak to Beverly or Deloris
http://techinfo.toyota.com/public/main/mdc.html
http://www.4crawler.com/4x4/FSM.shtml
1)buy a used one off e-bay
2)some Toyota dealerships may give you one or sell it for $10-20 (used) as most Toyota dealerships don't repair many old Toyotas and no longer need the service manual
3)some public libraries sell their old books as they are not in demand any longer
4)some free buy & sell classified papers,websites and bulletin boards may have some used ones for sale
5)some junk yards may have one laying around
6)some Toyota specialty garages may have one laying around and no longer use it as the vehicle may be too old and those mechanics probably have so much experience that they could publish their own factory service manual with corrections and "real world repair tips"
7)if someone has the FSM maybe they could scan all of the pages and post it on a site for all of us to download or view.
For scanned pages of factory service manuals for other engines:
http://www.brian894x4.com/Scannedmanual.html
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
http://www.showmesome.info/hilux/info/manuals/1KZ-TE
http://surf.mactherapy.com/1KZ-TE.pdf
http://surf.mactherapy.com/parts
http://www.spyderchat.com/1zzfe.pdf
http://files.matrixvibe.net/docs/1zzfe.pdf
http://landcruiser.free.fr/mans
http://www.turbosupras.com/pages/technical/tsrm.htm
http://www.lieblweb.com/tacoma/Mechanical/96TacomaDiagrams/index.htm
http://perso.wanadoo.fr/adherence.4x4/liens_techniques.htm
http://perso.wanadoo.fr/adherence.4x4/index.htm
http://www.asatraction4x4.cl/html
http://www.toyotasurf.asn.au/techsite/downloads.htm
http://www.grubinski.com/grubinski/automotive/toyota.manuals
http://www.carsoft.ru/files/4runner95di.exe
http://www.hotrodder.com/kwkride/tech.html
http://www.autoshop101.com/autoshop15.html
http://www.mtv411.com/sitemap.htm
http://www.toyota.com.my/index.asp?fuseaction=home.article&aid=40
http://www.newcelica.org/other/technical/index.htm
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM
Sorry to inform you, but no 2 injectors "fire" at the same time on a 22re engine. I've had an '86 4Runner, '93 pickup and '95 Camry all with EFI and with a distributor. As the rotor button rotates, fire is sent to only one cylinder at a time. Hence, only one injector "fires" at a time.
santrap53 is correct only one cylinder fires at a time so it begins like this 1-3-4-2.Thanks santrap53 for the correction.:)
Sidney® ™
Canada
Discussion Starter #6 (Edited)
we are talking about injectors not clyinder. Also were not talking about the dist and coil circuit but the fuel and computer circuit. I still think you wrong. If you look at the wiring diagram you got two wires from the compputer. no 10 and no20. each is wired to two injectors in parallel. then the ground are tired together before hitting the solenoid resistor. They is no way they can fire single wired like this.
So my question is , which two injectors are tied together. FSM pg fi-66
92 pickup xtra cab
there is no way your going to have 2 injectors fire at the same time, 2 pistons will be at the same point, but in different parts of their cycle.
but if you really want to find out pull your injectors, lable them and see if 2 "fire" at the same time
86 pickup 1 ton
i guess that having it fire two cylinders at a time would make one weird two cylinder engine.
1 - 9 of 9 Posts
