I had the timing chain tear up my cover and got the antifreeze leak into the oil problem. I've pulled the head with the entire intake assembly off as one unit, removing the wiring harness from inside the wrap of the intake assembly. Now that I'm finally reassembling, I have one plug that I can not figure out where it goes to. It is two female blade connectors in a "T" configuration in a black plastic housing. It is in the right hand wiring harness that the injector harness and such are in. Any ideas as to where this plugs into would be much appreciated...
D'mon
D'mon
