Driver's seat has a problem. It's the 7-way adjustable power seat, and everything that's powered works great. However, the crank knob used to adjust the recline of the back of the seat has a problem...it only cranks so far up.
I'm probably not being clear here, so I'll try to describe it more...
-When cranking clockwise, the seat will go all the way down towards the backseat.
-When cranking counter-clockwise, the seat will only go back up so far. And it's not even close to how far it should go. I can verify this by comparing it to the passenger seat, which goes up much further in terms of recline angle.
Any thoughts? The crank simply won't turn anymore when I use it. Is it possible to jam it?
