1 - 8 of 8 Posts
1976 Corolla SR5
So I got an aftermarket gauge installed in the Corolla last night to monitor temps. After idling a while, short drive and idle in driveway last night it sits at about 220•
For you 2T guys, is this too hot/somewhat normal/ slightly hot?
Water pump and thermostat are new (few months), radiator was checked professionally and revamped.
not sure how concerned to be
thanks!
Watch Gauge Speedometer Motor vehicle Measuring instrument
One with the farce
That’s too hot, but before you worry there’s something wrong with the car, check that gauge with another gauge in a pot of boiling water to confirm they both read the same.
1976 Corolla SR5
Discussion Starter · #3 ·
Can do. It’s brand new, but I should confirm it works accurately through testing.
Also, the sensor in the thermostat housing is fairly old as well, so there may be something there too.
One with the farce
I’ll check my book this evening.
One with the farce
Not super clear here but I think you probably had it right.
Book Publication Font Parallel Paper
Sleeve Book Font Material property Pattern
1 - 8 of 8 Posts
