1 - 12 of 12 Posts
2005 Tundra SR5
Toy lovers,
I would like to lift the front 2.5"-3" to level the truck without investing too
much and without affecting ride or mechanicals. What are my best options?
Thanks,
Doug
03 tundra accesscab
http://www.toyteclifts.com/tundracart.html#tundraliftkits
i have the 3" "basic pro" on my 03.
if you don't have billstein shocks on your truck, i would go for the 3" adjustable coil overs, and get the add a leaf and front diff drop kit separately.
otherwise, you would need a good coil spring compressor to fit the front level kit on your struts.
you would be offsetting your camber a little bit. so, you would be needing a front alignment after you're done.
2.5" lift for very little $$$
Go to fatbobsgarage.com or userid hammerhead4x4 on EBAY. They are a group out of Utah. They have everything you need for little $$$. High quality materials. I installed a 2.5" lift on my DC Tundra and it's awesome. It included front spacers for on top of the struts and an add-a-leaf for the rear. It even included a 1" differential drop for the front. All for < $150. If all you want is a front leveling kit, I believe they are < $60. Whatever you decide make sure you have an alignment done soon after the installation of the kit. My kit allowed me to install 285/70/R17 which is essentially a 33" tire on my truck. All-in-all I now have @ 5" of more height on my truck. The handling didn't change at all, same smooth ride it had before and mods. Good luck.
Old Fart
2002 Corolla LE
Toy lovers,
I would like to lift the front 2.5"-3" to level the truck without investing too much and without affecting ride or mechanicals. What are my best options?
Thanks,
Doug
Get the Bilstein 5100 Adjustable front shocks. Better than a spacer lift any day.
Old Fart
2002 Corolla LE
Would I need to change the springs too?
Great quote by the way!
No. Everything else about the front coilover stays stock. The shocks have 3 settings: Low, which is stock heighth, medium, which is level, and high which lifts it about 2.5 inches.
On my 2001 AC, I have mine set on high, and I added 1-inch blocks in the rear. The net result is level + 1 inch.
And just to let you know, once the shocks are installed they are not adustable so make up your mind ahead of time how high you want it.
2005 Tundra SR5
Discussion Starter #8
Hey Cyberbilly!
Thanks for all the info! I just have one more question. First of all, I will be going for 2.5 inches cause that's what I measure the difference from front to rear to be, give or take. My question is about what I read on the Bilstein site that says something about the 5100s being strictly off-road. I get off-road now and then but I am not into pounding the crap out of the truck cause I can't really afford fixing it due to abuse. I just hate trucks that aren't level and I could use the ground clearance at camp and in some of the other hunting spots I get into. I drive to work every day in this truck so I was just a little concerned. What's your take on all of that? Thanks again for all the info...
biknski
Old Fart
2002 Corolla LE
Hey Cyberbilly!
biknski
I'm a little confused because I've never seen anything about the 5100 Adjustable Shocks being strictly for off road. My ride is basically a street machine that takes an occasional trip down the Bunny Trail or onto the beach. I've had them for about one year now and have not had a lick of trouble.
Now, don't confuse the 5100 Adjustable shocks with the 5100 coilovers. They are two different things. Maybe that's what they are talking about.
2005 Tundra SR5
Discussion Starter #10
Hey Cyberbilly!
I finally got around to ordering the 5100s. Got em for the rear too from ShockWarehouse.com. Total bill $350.90 to the door. Y
You were right on the off road question I had . Was referring to coil-overs. Can't wait to get em and put em on. Thanks for the info!
Have a good one!
biknski
Old Fart
2002 Corolla LE
Hey Cyberbilly!
Have a good one!
biknski
$350.90 for all 4? Not bad.
I paid $200 for Just the fronts.
2005 Tundra SR5
Discussion Starter #12 (Edited)
I got all 4 shocks for that. The rear shocks allow 0-1'' of lift which would get me level plus 1. I didn't see them anywhere under 85-90 each. By the way, I was checking out your truck pics. Very cool. From the lift to the grill and the wheels, it looks good.
1 - 12 of 12 Posts
