Well it might be a while, I don't want to go cheap on this. Had these grills I ordered laying around forever and finally installed themOh yeah! It's always a great time when you post. Looking forward to seeing the progress & finished product
Damn, you went old school with the analog BOSS 4-band EQ setup.Analog equalizer installed:
Well I already started ahead of time before everything arrived, some wiring for the analog equalizer I want to install
Phonos from head unit to equalizer
Constant 12v and trigger I will pull from existing wiring from my sub amp
It will be placed here in glove box. Can't think of anywhere else that would work well
Wiring power here
Pic of unit
Next step to pre wire rest of car ready for speakers and amp. So phonos, power and speakers. I will also start cutting the wholes for tweaters and mids. Stay tuned
Ha I didn't realize it was a thing from the 90s but makes sense since the hu were junk in that era. However its definitely not unknown, this boss one I have isn't that old and quite a few companies make them.Damn, you went old school with the analog BOSS 4-band EQ setup.
Man, I would have just purchased a modern radio with a 10 band or more digital EQ. If you listen to modern audio media from digital format; an radio with a good quality DAC will better bring out the sound in your 3-way setup. However, if you are using the CD player with the original content(no MP3 files); then that old BOSS EQ may be the best option since CD quality is pretty high compared to MP3 files burned to them that usually requires a good DAC to bring back the sound quality from the compression process.
The Boss 4-band you have brings back memories from some of my old 90's car audio installs.
DSP is the software side of the digital audio conversion process to my understanding as a rule; however audio processing units are commonly called DSP. Overall sound quality is base on the actual DAC(digital-audio-convertor) chip-set inside the head-unit or audio processing unit(DSP).Ha I didn't realize it was a thing from the 90s but makes sense since the hu were junk in that era. However its definitely not unknown, this boss one I have isn't that old and quite a few companies make them.
However! I was thinking the same,it may not even make a difference and I've heard reports it can worsen the quality and add more interference and noise. I've had this laying around the garage and figured ide give it a try vs the equalizer on my Eonon Android unit. (Which doesn't have CD but can play FLAC)
I think ultimately you are right and i should get a better dac or they are called DSP in the car world (digital sound processor)
I got burnt out last night getting all the wiring in, will continue today and update as I go along. Maybe not of much interest to some but figured it was a cool upgrade the HL that you don't see much
Thanks for the info. Yeah I wasn't planning on keeping the Eonon I got it many years ago and it looked better than most without breaking the bank but I've actually been pretty impressed with the quality of the unit inside and out so haven't replaced it yet, when I do I'll go with a Sony or Pioneer. I ultimately prefer a standalone double din with a CD and no screen, I had a JVC in my last car that was very impressive and it wasn't even that expensive I think $120, had infinity reference 6x9s all around with a amp and sounded amazing. I do love my vinyl and am addicted to that wonderful analog sound, so I'm always going for a pure sound with good clarity and mids in my cars but it's tough!DSP is the software side of the digital audio conversion process to my understanding as a rule; however audio processing units are commonly called DSP. Overall sound quality is base on the actual DAC(digital-audio-convertor) chip-set inside the head-unit or audio processing unit(DSP).
Sony and Pioneer uses some high end DAC in their head-units; hence the superb sound quality of their head-units. Some of the cheaper Android based units has some low-end DAC; hence why I do not bother with the cheap android based head-units. I think Eonon is a good quality company based on reviews; I am not sure about the actually sound quality of the head-units they make.
As for the EQ from the 90's; I always added an slim 1/2 DIN 7-band EQ to my audio systems(under the headunit in the dash) since most of the older head-units only had bass,mid,treble settings without any subwoofer crossovers. The headunits became better in the 2000's and started to include 7 or more EQ bands and crossovers; so the need for the additional EQ unit faded away as the head-units became even better with DSP processing.
Thanks! Yeah that's gonna have to be the next step and I agree. That's what nice about car audio though, you can upgrade it more and more over timeWell done! As previously discussed, you’ll be able to better tune the brightness, etc. when you replace your heading with the better DSP and expanded EQ. I’m currently running an Alpine iLX-W650 with replacement speakers and a small powered sub. Very pleased with it. Most of my music is Apple Music streaming. Also a good amount of podcasts.
Enjoy the fruits of your labor, friend!
So you would recommend that head unit? Alpine iLX-W650. If so maybe I can find a used one for a bit less somewhereWell done! As previously discussed, you’ll be able to better tune the brightness, etc. when you replace your heading with the better DSP and expanded EQ. I’m currently running an Alpine iLX-W650 with replacement speakers and a small powered sub. Very pleased with it. Most of my music is Apple Music streaming. Also a good amount of podcasts.
I’ve been very happy with it. It is pretty basic in some aspects, such as customizing aesthetics (can’t change main wallpaper, illumination is only white, etc). It does not have a mechanical drive, so it is streaming content (via Bluetooth, Android Auto, or Apple CarPlay), satellite radio, usb drive, or radio. It does has video input for backup cam.So you would recommend that head unit? Alpine iLX-W650. If so maybe I can find a used one for a bit less somewhere
