1 - 2 of 2 Posts
I have a 1987 Tercel hatchback and the car didn't come with a tach. My problem is I don't know where to connect the tach wire. I removed the dist cap and saw a green wire in there but the space inside and the wire itself was just to small to splice. There is a black and brownish-orange wire leading into the green wire, would that also work or is there another wire hidden somewhere?
Thanks!
All you have to do is locate the distributor, and you'll see a blue wire with a connector on the end of it... this is the signal wire (green on your tach).
1 - 2 of 2 Posts
