That could explian a lot of things...And brings up a few more. Like why is it designed like that and is that statement valid?????? Someone wana call toyota corprate to verify his statement?
I'm partially skeptical about what they told you, and I'll tell you why.bjmn7d said:This past Saturday we took our car in for an oil change and tire rotation and I decided to explain the change in rpm when shifting between 3rd and 4th gear. I asked the service man if he knew about this and he said that it was normal operation for the car because the car will not shift into 4th gear until the engine reaches a certain temperature. Then I asked him if this was the same for all Toyotas and his reply was that it was indeed and that his 99 Tacoma does the same thing.
Sound believable? I'm not sure. I would like to think this problem is only minor, but why on earth would they design the car to meet a temperature setpoint just for switching gears? I don't believe this is a practice on my Chevy Corsica...or any other car I have ever driven.
The TSB TC008-06 does not appear to be working for anyone from what I have read. Should I be reporting this issue to the sales person I dealt with when I bought the car?
We have about 8100 miles now and up until November we never noticed the problem supposedly because the outside temperature was not an issue until then.
Now that u mention my 2002 totally did the same thing a few days ago during really cold weather. Even after warming it up as i do everyday.mrshyvley said:I had a 2002 Toyota Camry V6 before I got my present 2007 Camry V6.
I believe it to be true about the shift delay until a certain fluid temp is reached, because my 2002 did it.
I always would wam up my 2002 Camry V6 a little before leaving.Mistabullet said:Now that u mention my 2002 totally did the same thing a few days ago during really cold weather. Even after warming it up as i do everyday.
Well yes and no.Mistabullet said:So i guess toyota trannies have a unique way of shifting when the fluid is cold....?
Has anyone experienced this during warm weathers and after a proper warm up?
If not then it's a little more reassuring knowing that ur car isn't broke and that it's just doing what it was designed to do since we can trace this symptom back to the gen 5's (& a tacoma according to the technician in the OP).
i don't notice the flare when i'm in manual mode and others are using this as a way to avoid the flare in some cases.Recluse said:Hi-
I've been thinking about a 2007 Camry SE V6, and just found this site.
I've been reading up on this issue for a few days, and did a search, but there's one piece of information I haven't been able to determine: Are you all experiencing this problem in the regular automatic mode, or in the manual shift mode, or both?
Thanks in advance.
Using S and holding the car in 3rd so you can manually control when the shift to 4th happens, so you can let up on the gas momentarily to avoid the flare does make a difference.onsknht said:Using the Auto or S will make no difference, here's why.
1) Using S if you're in 3rd gear and shift to 4th the car functions the same as in Auto, only it is limited to 4th gear.
2) Using S and holding the car in 3rd gear defeats the problem altogether... It is a problem shifting between 3rd and 4th gear, right?
Warming the car up before driving it ALSO avoids the flare... You'll have to admit you're basically defeating the problem by not allowing the car to shift from 3rd to 4th.mrshyvley said:Using S and holding the car in 3rd so you can manually control when the shift to 4th happens, so you can let up on the gas momentarily to avoid the flare does make a difference.
I've been doing this to avoid my once when cold 3rd-4th flare, before I switch over to Drive and drive normally.
Feel free to do what you want, but this does avoid the once when cold 3rd-4th flare in my car.
i don't disagree that it is not a solution, but if you're concerned or bothered by the flare, using the sequential shift can minimize the problem.onsknht said:Warming the car up before driving it ALSO avoids the flare... You'll have to admit you're basically defeating the problem by not allowing the car to shift from 3rd to 4th.
You are demonstrating reason #2 as to why it doesn't make a difference to use S or Auto.
In no way a solution... I've found nothing in the owner's manual or from Toyota that says I must warm the car before driving or hold the car in 3rd gear in S mode for "x" amount of time.
In fact the owner's manual states the following...
"Normal starting procedure
The multiport fuel injection system/sequential
multiport fuel injection system in your
engine automatically controls the proper
air−fuel mixture for starting. You can start
a cold or hot engine as follows:
With your foot off the accelerator pedal,
crank the engine by turning the key to
“START”. Release it when the engine
starts.
Engine should be warmed up by driving,
not in idle. For warming up, drive with
smoothly turning engine until engine coolant
temperature is within normal range.
If the engine stalls...
Simply restart it, using the correct procedure
given in normal starting."
This falls in the "Low Speed Shift Flair" category/video and is probably the reason most do not see this problem. I can execute the problem at will every time I choose to do so, took me two rides to do 2 videos.
I'm only concerned/bothered because there clearly is a problem and I feel that I'm getting snow-jobbed by a multi-national corporation... And I think the only reason I'm getting fukced, is so the bean counters and board members can call the launch a success.tagpats said:i don't disagree that it is not a solution, but if you're concerned or bothered by the flare, using the sequential shift can minimize the problem.
Fuel economy becuase the car runs rich at idle... In addition to this the oil pressure is lower.Mistabullet said:Are there any damaging effects caused by letting your car warm up by idle?
Anyone know why toyota recommends driving it to warm up?
