21 - 24 of 24 Posts
3s-gte in a Camry?!?
'89 Camry Alltrac
I'd be surprised if it was swaybar clearance - it was likely exhaust clearance due to the balance shaft 'bump' in the oil pan. Later 3s-ge and 3s-gte engines do have swaybar clearance issues with the new oil filter mount location.
The gen3/4 Camry mount setup is very different than the gen2 (and Celica) mounts. 3 'bottom' mounts and the top dogbone instead of two hanger mounts and two (or three) torque mounts.
-Charlie
I honestly don't remember, but I do recall it was quite obvious that the 5S pan (from a Camry) would not work. Maybe it was the cross member.. The hump accommodating the gear for balance shaft assembly would not clear, as the stock 3S pan is a fairly tight clearance as it was.
'89 Camry Alltrac
Oh yeah! That would definitely do it. So N-S subframe, not swaybar.
-Charlie
91 Camry DX 5-Speed 3SFE, 88 Camry Base Auto
Discussion Starter · #24 ·
Noted to the above. It's been a minute since I've had time to work on this side project. Money also being a factor since I'm having the windshield replaced in the 88 Camry due to large cracks all across and the transmission started slipping in the work SUV, typical Dodge...
Pictures from the head being pulled off:
Automotive tire Bicycle part Automotive engine gasket Rim Motor vehicle
Light Motor vehicle Gas Engineering Nut
21 - 24 of 24 Posts
