1 - 8 of 8 Posts
· 3s-gte in a Camry?!?
'89 Camry Alltrac
I'm not aware of any 3s-fe equiped car that has a MAP sensor.... What car is this for? Your car probably has an air flow meter - good luck finding a replacement - you can research pinouts and maybe use an air flow meter from a 3s-gte or something. Good luck!
-Charlie
· Grenaded piston
^ He has a Rav 4 with a 3S-FE.
Maybe it has a MAP sensor instead of a AFM like our Camrys. I couldn't tell you for sure, never looked under the hood of a Rav 4.
If it does have a MAP sensor, I wonder if one from a 3S-GTE will work or not. I know it works on a 5S-FE.
1 - 8 of 8 Posts
