WHy would you want to do that? It will have less power and make your car unbearably slow. Also, it won't fit without modification.
It will fit, but I don't know if it'll mount.Studious said:will a 3sfe tranny(auto) fit into my gen 3 camry 1993 4 banger 2.2L?
Its possible just to pull the tranny, but good luck doing it.also when i pull my transmission out do i have to pull out my engine becuase my tranny is sitting on my frame and the only way i GUESS is to pull the engine out as well...
Compare both trannies and look at the holes on the bell housing, the holes on the bottom of the tranny, and the sensors.Studious said:i noticed the mounts are different will this cause a problem.
