infoprodigy said:
So say I got a 2nd gen clip, what is best route for tranny, axles. Would I want to go with v6 tranny and axles.
1. Your stock manual tranny. I don't know how long it'll hold up to the power of a 3S-GTE though.
2. Tranny from a 86 - 89 Celica GTS (3S-GE).
3. Tranny from Celica All Trac/GT4 (if you buy a Celica clip).
You need to make a block off plate for the driveshaft output. And possibly weld up the diff.
4. Tranny from MR2 Turbo (if you buy a MR2 clip).
The tranny will not work as is, it needs to be modified to work in a fwd application.
5. E153 from a V6 Camry/Solara. Same tranny as the MR2 Turbo, but no modifications are necessary.
So if I get a core 3sfe would i want the short block or long block.
Would it be easier to just build up the long block and replace the whole thing instead of taking parts from one to the other, or will it not make much difference.
I would get a long block (block + head), that way you have another almost complete motor to work with.
I say almost cos you still need to swap over your existing intake + exhaust manifold and acccesories (alternator, ps pump, etc..).
As far as using 3sgte pistons and rods what else is needed to build it up right.
Are you going all motor or turbo?
If your going all motor you don't want to use pistons from a 3S-GTE. They have a low compression ratio.
