1 - 20 of 30 Posts
Hello,
I have a question.(iám dutch so my english isn't so good SORRY)
I had a trackday on the circuit, in holland on Zandvoort.
But after it, the engine didn't drop.
So the engine have a high engine speed end wil not drop.
it makes 1000 RPM when the engine is running in parking mode.
And after the trackday when i left the circuit the engine have rough idling. between the 850 RPM and the 1500 RPM, and it stopped after 15 min.
Can please somewone help me??
Greats Tyn
Discussion Starter · #8 ·
i didn't use race gas .
i did this now :pull the negative battery terminal off for 2 mins.
But the problem is still there.(sorry)
something alse is strange,when i step full on the accelerator, and let it go again the RPM meter go's verry slow back.
maybe this is some information you helpfull people can help me in the further??
1990 Celica GTS
ICV need some cleaning. Your intake and/or injector probably were dirty. They got clean up a bit after you race. When you race, engine run hot for longer time and usually will clean some of the carbon build up. Idle control valve don't like any changes. Remove intake hose and clean the throttle body with throttle body cleaner. Remove EFI fuse or battery terminal before you start cleaning to rest ECU.
You'll need to set idle and timing too.
Discussion Starter · #11 · (Edited)
the timing belt is not jumped a tooth.
I have clean the throttle body ,it was dirty YES,but the problem is still there.
I try to tune up the idle but the adjust screw is already on the bottom(to his end), so i can't get the idle lower with the adjust screw .
In the weekend i going to clean the sparks,maybe the sparks are untuned(if thats possible).
are there more suggestions for me to look at??
please let me know and thanks already for the help i have get from you all already
wow ok check your tps check all the valves around the engine and make sure they all work.
you think thats a problem...
my car idels at 2000 when cold idels at 1500 when warm and if its driven for like 5 mins it idels from a 1000 to 1500 then drops back to 1000 and then climes to 1500 ;)
Resident asshole
Corolla
You shouldnt fiddle with that unless you are using an exhaust analyzer, you might do more damage than good.
Check ALL of the vacuum hoses, might be that one of them is loose.
1990 Celica GTS
I had similar problem, it was the ICV. It let in too much air so the idle screw does nothing. It does sounds like you got too much air either from the ICV or vaccum leak.
Exhaust analyzer to set idle??? Or you mean something else? I just use a good timing gun with tach to do that :p:
Discussion Starter · #15 ·
Oke,it's like that yes,
but what is a ICV,is that a valve or something??
1 - 20 of 30 Posts
