1 - 3 of 3 Posts
i have a 92 camry se v6 5 spd. im hearing a loud sqeak from the front sectoin of the motor where the timing belt crank pulley is. AT cold start you hear nothin but as the car warms up the sqeak (which sounds like a belt sqeak) gets louder and doesnt go away it. when you rev the car the sound gets louder. i got 160xxx on the car now i change the timing belt, water pump and both idler pulleys at 135xx can you guys help me out
It may be related to the timing belt change and the quality of components you used, but it also may be the auxillary belt for the power steering or the one for the alternator and A/C. Have you checked the tension on those belts? Maybe the power steering bracket has slipped causing loss of tension on that belt? Is the A/C engaging? If you are not sure, maybe pull the A/C fuse and see if the squeal is still present next time.
dave mc
1 - 3 of 3 Posts
