1 - 10 of 10 Posts
2008 Tacoma
I've got an 08 standard cab 4cyl Tacoma with manual transmission. I'll be towing a bike trailer. It's a 3000 lb trailer, max.
A class three hitch is rated for 5000 lbs. With that engine and manual trans I don't think I could pull 5000 lbs.
Should I put a class three hitch on it anyway or look for a class two?
All of the sources I've checked only have class three hitches including the Toyota dealer.
I believe the bumper itself can handle up to 3500lbs. Does this sound right?
What is the simplest and least expensive way to stiffen up the back end for towing? springs, shocks, or added leafs?? That is, if I even need to.
Thanks!
tacoma
· Theatre Nerd Person...yea
Tacoma
My manual says 3500lbs without towing package, 6500 with towing package.
Thats with the V6, the I4 is only rated to tow 3500lbs with or without the tow package.
Tacoma
WHat kind of increase would I get in Tow capacity if I install a tow package (oil coolers, hd battery, etc.) on a 4 Cyl? Anyone with experience? Thanks
Reg. cab, 4cyl, 4 speed auto.
None...no matter what the max rating that Toyota will give the 4 cyl is 3500lbs. You would be wasting your money, the small 4cyl engine just isn't powerful enough to tow more then that. It's not a matter of cooling or battery power.
1 - 10 of 10 Posts
