1 - 3 of 3 Posts
2018 Camry XSE V6
Toyota is conducting a safety recall involving certain 2020 Model Year Avalon Hybrid, 2020 Model Year Camry, 2020 Model Year Camry Hybrid, 2019-2020 RAV4, 2019-2020 RAV4 Hybrid and 2020 Model Year Lexus ES 300h in the United States. Approximately 44,000 vehicles are involved in this recall.
The Problem: An engine block was manufactured incorrectly, which may cause coolant to leak during normal engine operation... engine damage could cause oil to leak.. risk of fire.
The Fix: Dealers will inspect the engine block casting serial number and, if it’s determined to be involved, will replace the engine and engine block with a new one for free.
Toyota announced that about 250 out of the 44,191 recalled vehicles will actually need their engine replaced
Update:
Here's some more information.
Defect Information Report pdf
Manufacturer Notices to Dealers pdf
Only 4cyl. and hybrid are affected.
The vehicles that are affected are between the manufacturing dates below:
Camry Gas | September 9, 2019 to January 15, 2020
Camry Hybrid | September 16, 2019 - December 19, 2020
2014 Camry LE, 2020 Camry Hybrid LE
In a written statement, Toyota announced that about 250 out of the 44,191 recalled vehicles will actually need their engine replaced, but dealers will have to check the serial numbers on the engine blocks in recalled vehicles to determine whether they were part of the faulty batch.
The problem started in September 2019 at a Toyota-owned factory in Tennessee that manufactures engine blocks for Toyota and Lexus vehicles. According to a written statement from the automaker, a water flow meter at the factory failed while some engine blocks were being cast. As a result, these blocks did not cool properly, which caused cracks to develop.
Toyota said it discovered the problem when it found vehicles with coolant leaks during inspections of new vehicles at factories and dealers. Although the majority of affected vehicles have already been sold to consumers, some are still on dealer lots and cannot be sold until they have been repaired.
When contacted by CR, a Toyota spokesperson would not comment on whether there have been any crashes or injuries related to this problem.
The Details
Vehicles Recalled
• 2020 Toyota Camry sedans manufactured from Sept. 12, 2019 through Jan. 15, 2020
• 2020 Toyota Camry Hybrid sedans manufactured from Sept. 16, 2019 through Dec. 19, 2019
• 2019 and 2020 Toyota RAV4 SUVs manufactured from Sept. 12, 2019 through Nov. 20, 2019
• 2019 and 2020 Toyota RAV4 Hybrid SUVs manufactured from Sept. 12, 2019 through Dec. 10, 2019
• 2020 Lexus ES300h sedans manufactured from Sept. 16, 2019 through Dec. 18, 2019
• 2020 Toyota Avalon Hybrid sedans manufactured from Sept. 16, 2019 through Dec. 13, 2019
The problem: Due to a manufacturing issue, the engine block may be cracked. As a result, the vehicles may overheat, stall, or catch fire.
The fix: Dealers will check the serial number on the engine block to determine if it is part of a faulty batch. If it is, dealers will replace the engine free of charge.
How to contact the manufacturer: Toyota said that recall is expected to begin April 6, 2020. Owners may contact Toyota customer service at 1-888-270-9371 or Lexus at 1-800-255-3987.
NHTSA campaign number: 20V064. Toyota's own number for this recall is 20TA04. Lexus' own number for this recall is 20LA02.
Check to see whether your vehicle has an open recall: NHTSA’s website will tell you whether your vehicle has a recall that needs to be addressed.
1 - 3 of 3 Posts
