1 - 3 of 3 Posts
Haven't Driven the car almost a year now. Car will crank but not start.
Fresh gas
Fuel Stabilizer
Starter Fluid
* have all been done
any suggestions?? fuel pump maybe? if so, where is the fuel pump located?
Homer Lusk Collyer
AE92
Fuel pump is located on the engine near the valve cover. Follow a fuel line from the filter towards the engine. You can also pull off the return fuel line and make sure that there is fuel.
Other than that, it could be the timing if that somehow got messed with. Or faulty ignition components.
Does it crank over strongly? Have you tried jumpstarting it? How about push starting? Push starting is my personal favorite method for starting reluctant cars.
iAzn
1988 toyo Corolla DX
Check your spark/ ignition system (distributor, wires). Mine went bad when it sat for half a year, tried cranking it and no start.
1 - 3 of 3 Posts
