1 - 20 of 25 Posts
toyota corolla
4AFE 4AFE 4AFE 4AGE 4AGE
CAN ANYONE TELL ME WHAT PARTS WILL I NEED TO DO A HEAD SWAP? (head gasket ect.?) IM PLANNING TO PUT SWAP MY 4AFE HEAD FOR A 4AGE HEAD ON MY 1990 TOYOTA COROLL SEDAN.
IT WILL FIT RIGHT?:hammer: ANY INFO WILL GREATLY HELP ME OUT THANK YOU.:D THANK YOU THANK YOU
it will match. but it isn't worth the money or the time, especially since you can get an entire motor for less than $500US from a japanese importer (even cheaper from a junkyard).
I swapped the entire motor over.
toyota corolla
Discussion Starter · #6 ·
thanx :thumbup: my car ate up almost all my doe$$,i recently change my tranny cuz it wasa fu*k up,so then i was thinkin :confused: if i already had the tranny i might as well just take out the head and block to the shop for a little "head job":rolleyes: and get new rings and stuff for my block.:hammer: MAN!what a bad idea................now im running on only three cylinder:lol: fourth cylinder no compression and thats why i want to just swap my head for a 4age head.ive heard that it fit right on my 4afe block...any idea on wat the hell is the problem ?????????:eek:
my $400 US motor: http://www.cardomain.com/memberpage/219038/8
c'mon man... i'm cheap, but not THAT cheap.... you're thinking i did just the head because i DID however keep the 4a-fe ecu (which we modded.... so it does see 7800 rpm's ;) )
and details on the entire swap:
http://www.cardomain.com/memberpage/219038/9
the WHOLE thing cost me around $1600.... which included the following:
new rad
new exhaust (including high flow cat, 2.25" piping, new muffler)
new KBD header
MSD 6al/blaster 2/8910 eis tach adapter (ignition)
New serpentine belt
New timing belt
New plugs, wires, cap & rotor
a couple new sensors
4a-ge flywheel
Rad hoses
4age FWD thermostat housing
new thermostat
new oil filter
and I've got to say... i've spent a LOT of money on this car (probably $6,000US+) and that $1600 is the best money i've spent (right behind it is the suspension)
the blocks are essentially the same.... all of the internals, however, are not the same. And i doubt that any of the 4a-fe blocks had oil sqiurters like the later years 4age's do.....
and the 4age does not run at 10.5:1.....
bigport is somewhere around 9.5:1 or 9.8:1... not 100% sure
smallport is 10.3:1
silvertop 20V is 10.5:1
blacktop 20V is 11.0:1
4agze (early) is 8.5:1
4agze (late) is 8.9:1
5M-GE
Indeed.
A guy on the Cressida forums performed this swap on an AWD AE92 (AE95??). Yes, his compression went up. I think.
4Aaron GE said:
Hey, how did you manage to mess around with the 4A-FE ecu?
:D
actually, i didn't get to see that part.... when racer25 (shawn) came over to where we were doing the work, I had to head off to the junkyard to find a long ass throttle cable.... when i left, shawn started to pull it from the car... when i got back, he was walking out of the house with it finished..
i know the basics of it, though.... basically changing the crystals inside to slow down/speed up the clock speed.....
1 - 20 of 25 Posts
