1 - 5 of 5 Posts
I hope that someone can help me with a problem regarding the 4afe,went out for a 2 hour drive, no problems, came to start the car again to go home, nothing!!!spinning over but not starting, getting a spark, fuel okay, checked for power at the injector nozzles, and I have 2 12 volt supplies at them!!!, one continues and one pulsing, check bores and lots of petrol in them , plugs wet thru,changed ecu, still the same .Ive run out of ideas now, can anyone help PLEASE PLEASE:sosad: :sosad:
If you have spark and fuel, I would think it would at least run, even if poorly. However, I did see a post a while back where the throttle position sensor was the culprit. Maybe someone else can chime in with something more helpful.
1 - 5 of 5 Posts
