1 - 7 of 7 Posts
Have a 2009 Tacoma. 4WD hasn't been used much in quite a while. Will this cause a problem in lubrication when we do use 4WD? How best should we deal with it?
Run it ever so often on wet pavement. Just for relubrication. That's about it.
No, it will not rust or deteriorate somehow but I do feel your question. Lube drips down from all the gears and chains.
Just run it ever so often. Buttons do corrode, if not used (Silverado owners know what I mean), even stick shift gets sticky to move.
My Other Truck
Welcome to TN! Good advice above, no harm done but the 4WD bits do like to be used occasionally. Avoid engaging on pavement if possible, especially don't engage 4WD on dry pavement to help prevent the drivetrain from binding.
1 - 5 of 5 Posts
carilc, the owners manual recommends 10 miles per month. We don't have enough rainy weather here to allow that. So it goes in alot when we have lots of rain, to make up for the drought months. There can be some corrosion of the switches inside the transfer case which can cause problems.
1 - 7 of 7 Posts
