I believe sometimes a car needs to "stretch"."Italian Tune-up"
Exactly, people baby their cars too much and cause more issues never reving past 3k rpm."Italian Tune-up"
Just curious, but you never changed the spark plugs? Even iridium plugs should be changed at 120k miles.'03 Tundra 130,000 miles in 3 years - Timing belt at 100k
'04 Rav4 140,000 miles in 11 years - Serpentine belt at 100k
'08 Tacoma 160,000 miles 8 years - Water pump at 90k
'16 Corolla 120,000 miles 5 years
None had anything else done other than oil changes and coolant replacement.
None had any issues with the engines and were still running strong when traded/replaced.
I was mainly referring to major work/repairs and "additives" that dealers like to push.Just curious, but you never changed the spark plugs? Even iridium plugs should be changed at 120k miles.
Well, antifreeze/coolant is still very important in warm climates and also contains rust inhibitors to keep things clean. I agree though if you stay on top of regular maintenance there is little that needs to be done in addition.I was mainly referring to major work/repairs and "additives" that dealers like to push.
Yes, recommended maintenance was followed including plugs (do them so rarely that I overlooked them). I had the new plugs for the Corolla in the trunk when the guy ran the red and totaled it.
I had just changed the oil and filters the weekend before the accident, but the plugs had not arrived yet. 5 quarts of brand new Mobil-1 on the ground. The guy at the impound yard joked that he actually has people ask if they can drain the oil and gas. Fortunately, I was planning to refuel that afternoon, so I only lost 1/4 tank.
My main point being: Oil in the crankcase. Coolant in the radiator. Gasoline in the fuel tank.
Using quality fluids and recommended service intervals, that's all that is needed for any vehicle.
Push the maintenance or use cheap products, and all bets are off. We don't really need "antifreeze" here in SoCal, and people tend to neglect their coolant system until it causes trouble.
When it does cause trouble, you take a look in the reservoir and 9 times out of 10, you'll find a muddy sludge in the bottom of the bottle.
Ya, that might need a flush and some chemical treatment to clean and neutralize the mess.
Oh it absolutely is. Like I said... let it go and you'll end up with a layer of goo in the bottom of the radiator, just as you do in the reservoir.Well, antifreeze/coolant is still very important in warm climates and also contains rust inhibitors to keep things clean. I agree though if you stay on top of regular maintenance there is little that needs to be done in addition.
Oh, okay. I must have misread or misunderstood what you were saying.Oh it absolutely is. Like I said... let it go and you'll end up with a layer of goo in the bottom of the radiator, just as you do in the reservoir.
I wasn't saying that it's not important to use the proper coolant... just saying that in SoCal, it is a very neglected system because we don't need freeze protection.
i should envy your rust-free & free-from-salt life but i honestly don'tOh it absolutely is. Like I said... let it go and you'll end up with a layer of goo in the bottom of the radiator, just as you do in the reservoir.
"Italian Tune-up"
I do the Italian stretch sometimes multiple times daily.I believe sometimes a car needs to "stretch".
Push out them carbon deposits. It does a world of good. 🤣I do the Italian stretch sometimes multiple times daily.
Helps regulate the planets core temperature too, so we all can have 365 days summer & no other seasons lmaoPush out them carbon deposits. It does a world of good. 🤣
i wish my truck would stretch better, i got roastedI believe sometimes a car needs to "stretch".
I'd blame a tired drivetrain.i wish my truck would stretch better, i got roastedon the I-80 racket today by some dum Chevy compact car hauling it down the middle
.... so much HP in the taco that is not ever fully realised
i blame a built-in speed limiter whatever, i was near the max! barely over 3k rpmsI'd blame a tired drivetrain.
