Hi guys.
I've had an interesting cold start issue. If I leave the car overnight or for a day or so the car will not start on the first try. I'll turn the key, it will try to start, the lights on the dash will go completely, then the car will stumble a little.Turn the car off, then to start, the car fires right up and runs perfectly.Also i get slight flat spot when accelerating during the warming up.(While driving.)
1)New ECT sensor (For ECU)
2)New TPS.
3)Throttle body and IAC valve removed out of the car and cleaned.(Also replaced IAC valve o ring and throttle body metal gasket.)
4)Carried out on car fuel injector clean 4 times.
5)Reset ECU by disconnecting the battery negative for 30 min.
6)new fuel filter and complete fuel pump unit.
7)New spark plugs and leads.
8)New air filter.
When the car reached to the normal operating temperature running perfectly.
Recharged the battery and load tested passed.(12.72v open circuit voltage and 10.68v with load.)
Also fitted new spark plugs and leads installed few weeks ago but no difference.Cant see or hear any vaccum leak.
cheers.
bob.
2)New TPS.
8)New air filter.
cheers.
bob.
