"I would think you are going to need abigger fuel pump than the 3SGTE one."
That's correct. ALSO....go to Ebay. Walbro (aka Whinebro) 255lph pump is about $80 new with warranty. 255lph is gonna hold you up to 350hp without nasty strain on the pump.
"jekylandhyde, i dont understand when you say "if you are properly launching the car the you should put down power to both wheels". Ive too also laid down rubber with the torquey bottem end'd 5sfe in 1st easilly. But, ive always spun the passanger side tire. And the td06 is a VERY underrated turbo. The t3 you have sounds like a nice turbo, but i would have gone with probably a garret t3/to4e 60 trim with a .63ar. Because the 5sfe being the extra .2 liters more than the 3sgte can really spool a turbo quite a bit faster than the 3s and can hold that power till redline because of how low the redline is. But anyways, it seems like you have a really really nice setup, are you going with the 3sgte head??"
Anything more than a T3/T4 super 60 is gonna be such a waste. In fact, that particular turbo is a waste. As Hyde said, the 5sfe head has way less flow than the 3sgte head. If your T3 (or whatever number you splurted out up there) is gonna max out at 19psi, then I believe you're gonna kill it and your engine trying to run more. Since the flow qualities of the 5sfe head are kinda low in comparison to the 3sgte, I speculate that your maximum power output / efficiency will be somewhere around 12-15psi on that T3. Any more than that and you'll create the wrong pressure situation. (Exhaust manifold psi higher than intake manifold psi, resulting in more air backed up through the charge pipe than the engine could burn, slowing the turbo's spooling and creating more strain on it.)
I'd say, with the setup you're running, you'll probably see somewhere around the 250-270whp range at around 12-15psi. I'm not sure how much you can push through your MAF, and that makes another problem if it's small.
There are so many variables to consider when turboing a N/A car, it's really tough to estimate what you'll end up with as far as whp and tq. I'd like to know what you get on the dyno, however, as I'm curious to learn more about both the 5sfe and 3sgte.
