that air is aptly called...blowby. means the rings aren't doing 100% of the sealing, which is normal. the VOLUME of air coming out tells you how bad it is, but if you got good compression on all cylinders, you really should just make sure you've got a new pcv valve and the breather line is clear of blockages. If you work on mostly older v8's, they have breathers on each valve cover to vent the gases to atmosphere. we don't do that because then you're venting gas fumes from the blowby, and hydrocarbon pollution is socially irresponsible. now we put it back into the intake for the environment and the mpg bump, mostly the environment tho.
anyway, if you only have a little blowby, no biggie. if you can set a hat over it and it floats, it's bad. if the car runs smooth, hey, just make sure it vents back to the intake and forget about it. no biggie!
