5sfe Engine timing advancement?
2116 Views 5 Replies 4 Participants Last post by  RichieRichJP
Hey guys, My question is about advancing timing on the 5sfe found from 97-01, would the only way to advance timing would be to control the ignitiion system? or is there another way that timing could be advanced through crank sensor?
1 - 6 of 6 Posts
i think you have to have a btM. AFAIK, you're not supposed to advance timing. The stock timing is 10 degrees and if anything, don't go lower than 8 on a turbo. So I've read.
I don't know too much about timing myself
btM ?
Bear
the msd btm won't work for 97-01 5sfe because we're distributorless. The only thing I remember working was the split second tmc1 but it uses the ignition system. I'm in the same boat as you, let me know if there is another option
btM ?
Bear
Boost Timing Master
MSD does sell ignitions for distributorless cars, if I remember correctly. You should call them and ask. I still haven't looked into it that much yet, but it's actually on the top of my list, that is if I get my turbo parts soon
1 - 6 of 6 Posts
