Slow-yota said:Hey, I have a 93 camry 5sfe i was wondering if a Jspec 3sgte from a cellica would match the motor mounts in my car
Yes. E153 from Camry Solara manuals tend to be used in this project.... and would i have to swap out my trany too? im not sure if my trany would hold that much power.
thanx, Chris
thats wat i was thinkin about doin before i dicided to go with a whole 3sgte... but fe blocks are aluminum and they proly couldnt hold the boost and blow up which would not be good ...gte blocks are ironYangS said:
Somewhere in the camry forum someone said about leaving the 5sfe block and putting on a 3sgte head. I think this would be very unique but may also have a lot of problem.
I think JDM ones are stronger.ur_mom said:why jdm 3s-gte? why not domestic one..
It has more HP. I think it was the j-spec camry which is like 140-50 hp compared to the 133. BTW this is 5s-fe stats.ur_mom said:stronger head? block? valves? wat?
not necessarily. 92-94 5SFEs are iron blocks, all other years are aluminum. Head type doesn't reflect what metal was used for the engine. F heads have more even power spreads, G heads have a sportier power spread.Slow-yota said:..but fe blocks are aluminum and they proly couldnt hold the boost and blow up which would not be good ...gte blocks are iron
