I have heard in a couple of conversations that 2jz valves will work in a 5sfe head with head work (of course). Here I have listed the specs of each valve and need help from someone to determine with springs, retainers, guides, and locks to use. Also what will need to be done to the head to make them fit. I am trying to compute the numbers myself and am only making myself confused right now.
5SFE HEAD
INTAKE VALVE- 33mm head diameter x 97.5mm stem length x 6mm stem diam
EXHAUST VALVE- 28mm head diam x 98.5mm stem length x 6mm stem diam
2JZ HEAD
INTAKE VALVE- 34.6mm head diam x 98.55 overall lgth x 5.98mm stem diam
EXHAUST VALVE- 30mm head diam x 99.1 overall length x 5.98mm stem diam
What do you guys think? If I can figure out what to use, I will make this happen.
5SFE HEAD
2JZ HEAD
