Hi all!
I have a 1991 Toyota Celica GT and after owning it for a year and a half im finally deciding to build it :smile: It currently has a 5SFE engine and is automatic. Im planning on building a 5SGTE and have some questions i cant find anywhere and hoping you wonderful folk can answer them :grin:
-Would the 3SGTE transmission fit into the 5SGTE engine?
-Will the 5SGTE bolt right on to the stock motor mounts?
-Can i use the automatic drive shaft (from my celica) for the 3SGTE manual transmission?
-For the block i plan on using a 98 Camry 5SFE with parts from a SW20 3SGTE, will the parts still be compatible to make a 5SGTE (and will it bolt on to the stock motor mounts) (i have no access to a wielder so im really hoping nothing custom needs to be made)
Below Im listing all the parts ive found on ebay for this build and im hoping you guys can let me know what im missing
- https://www.ebay.com/itm/94-97-TOYO...-SPEED-TRANS-WIRING-SW20-3RD-GEN/254265115078
(planning on stripping this engine and tranny to make the 5SGTE)
- https://www.ebay.com/itm/JDM-Toyota...ch-Brake-Pedal-Set-RHD-M-T-90-99/282666317489
(these pedals are right hand drive,will they still work for a left hand drive car and can i still use the celica's accelerator)
- https://www.ebay.com/itm/Clutch-Slave-Cylinder-Aisin-CRT-090-fits-92-95-Toyota-MR2/303183589972
(pretty sure the engine already brings this but ill still add it here just in case)
- https://www.ebay.com/itm/Techna-Fit...e-1990-1993-Toyota-Celica-GT-GTS/361687031481
(SW20 clutch lines)
- https://www.ebay.com/itm/Toyota-MR2...bles-5-Speed-91-99-OEM-JDM-3SGTE/143240028221
(gear shift linkage)
- https://www.ebay.com/itm/ST185-3SGT...urbo-SW20-Alltrac-JDM-Toyota-OEM/273823661715
(not sure if this ecu will work)
- https://www.ebay.com/itm/1991-1995-...Shift-Box-93-Turbo-Short-Shifter/163753475556
(MR2 short shifter all i need i a cover and a knob)
-1998 Toyota Camry 5SFE crankshaft and block
(both found locally in junkyard)
Thank you all for reading my first post looking forward to all your replies :smile:
(SW20 clutch lines)
