1 - 3 of 3 Posts
I recently bought a 2005 Toyota Tacoma Crew cab 6 speed. I have had a couple issues my tach is working about every other time I start it. But my biggest issue is the tranny I got in this morning and it was like there was no reverse. I finally got it to find reverse. And than I stopped at a couple stop signs and had trouble getting it to find 1st gear. Now it is working fairly good but when I have to backup it is still tricky to find reverse. It almost acts like something is sticking in there. Does anybody have any ideas on what I should start out with. Thanks in advance!!
Manual transmission? Change the gear oil. Bleed the clutch hydraulics. Make sure clutch pedal is down to the floor and not blocked by floormats. Replace the shifter bushings.
I'm having similar issues as I just purchased same vehicle. I hope that it's just a matter of getting used to it. I've also found that you have to push pretty hard to get it to go in. I'm also finding 1st gear to be really low. I've just been coming out of 2nd , like the old creeper gear, and it seems to work fine. I don't know if it will cause problems down the line though.
1 - 3 of 3 Posts
