In the process of replacing the head gasket on our 96. It failed on Tuesday with massive clouds of smoke out the tailpipe, with ~285K miles on the engine. Anyway, as long as we've owned the car, through a couple of different radiators, the coolant would always turn a rusty color not long after I would fill the system with 50/50 Prestone Green and distilled water.
Well today I found out why. I shined a light down through the coolant passages into the water jacket around the cylinders, and found tons of rusty gunk and actual pieces of debris all in and around the cylinder walls! I'm not really sure how to get the stuff out, if it's even possible, or if I should even worry about it. I'm thinking someone years ago before us may have used some type of radiator or block/gasket stop leak junk in the engine. But we've put nearly 200K miles on the car ourselves and it's never really been a problem before. What should I do?
