ok... if you want to use a 4age ecu... then you need the 4age wiring harness (and you need the ecu that matches the 4age head you use... bigport and smallport ecu's are different)... then you'll have to customize the harness to the rest of the car to work with the 4age harness.... then you will also need to change some wiring (extend the starter wires, extend the alternator wires etc...)... there also is no header that will fit, that i know of.. a 4afe and 7afe headers are different... and a 4age also uses different headers... you would need a 4age upper portion, and it would need to be lengthened to reach around the taller 7a block.... you'll also need the AFM for the 4age... and if you get a bigport, you'll need all of the t-vis stuff
