so just getting some more opinions here....thanks for the help already
ordered a head gasket set yesterday for my '90 cressy. should be here tomorrow. got it from the dealer, so its the revised OEM HG. everything i read says 'use at least 70 ft-lbs or all hell will break loose! again!'. well not exactly, but close enough:lol: whats the general consensus between the cressy and mk3 supra owners? will 70 prevent future premature HG failure? does this work with the OEM HG or is this more for the metal HG's?
secondly, since the mechanic is going that deep into the engine anyways, i'l giving him a few other maintence jobs to do. he's very honest and would charge next to nothing besides parts (if necessary) if he's already going in there. so far on my list looks like this (in some order)
1. flush radiator - it has to be drained and removed anyways, so why not?
2. check/replace timing belt - no idea when it was last done. there's a date written on the cover, but god knows what that is. could be from a wreckers for just a repalcement cover for all i know.
3. clean any carburization from cylinder heads/walls using a wire brush - thanks to the online MK3 TSRM.
4. is it worthwhile to check/clean valves? what about valve lash?
5. anything to add on the list of 'while you're in there'?
