when i first got the car the guy i got it from claimed that it had a new head gasket, he also changed either the crank or cam seals (can't remmember), attempting to stop this leak (which blew oil over the entire engine and made it impossible to narrow down the source), that didn't help. so i changed the valvecover, pan, and turbo gaskets, then i cleaned the engine well. i ran it for a while with no leak; so... i took it for a test run. upon return i found the insulation on the front of the hood was dripping with oil, the air intake ducts were covered with oil and there was oil dripping from the front of the pan gasket. the top and sides of the engine were dry so this leak is narrowed down to the front othe engine, but still massive. i retightend the pan a couple of times (can you over tighten these bolts?) but that didn't help.
what next?
:headbang:
what next?
:headbang:
