1 - 3 of 3 Posts
Hi everyone!
First time posting, not sure if you guys can help but I am out of options!
I own a 1983 Toyota Corona CS with the Starfire 1X engine. Ever since I bought it I've had problems with what I am assuming is the carburettor. It fires up fine and idles fine (when it's cold) and even drives fine but as soon as its warmed up and I come up to an intersection or stop sign the rpm drops and will run very rough until it stalls once I've come to a stop. It was sitting for about 1.5-2 years and not started so I have cleared the fuel lines, replaced the fuel filter and checked the spark plugs. It does seem to backfire a lot once you let off the accelerator as well. I am assuming it's something to do with the carburettor but I am not sure it could be something else entirely. Any insight would be much appreciated! Thankyou!
I will attach a photo of the car for reference.
Brit, in Bitz!
Carina2 1991
Hi m8 :smile:
My 1.6 '91 4A-F does pretty much the same*... (But not all that often = live with it)
... Agreed likely carb :frown:
*no back pops
Back pops might indicate timing :wink: ..?
2sav
Soylent Green sales
rock crawler
If its carbed it would have a choke, so maybe the choke is not shutting off once it gets warm.
The timing would be the other thing to look at.
1 - 3 of 3 Posts
