1 - 8 of 8 Posts
New to Toyota and now I have a huge problem. Main fuse blew somehow and replaced 80 amp fuse. Now truck still wont start. No spark from coil. Checked coil; seems good. New pick up in distributor still no fire. Junk yard Igniter assembly and still no fire. Please help, I herd this was the best engine toyota ever built, now I cant use the darn thing.
Thanks for any reply.
· Soylent Green sales
rock crawler
And more important, why did an 80A fuseable link blow ???
Discussion Starter · #4 ·
Still having trouble.
sorry, I go to school full time and I have not had a chance to mess with the problem.
Ok, I replaced the coil same problem, I replaced the pick up in the distributor, I have tried a junk ignition assembly, and still no spark.
You asked an important question: I don't know why the fuse blew. I do know that the key was left in the ignition with the lights on for a while. If there is anything else; my son is not telling me.
Am I starting in the wrong place? I also downloaded a manual on a 87 p/u and went through the trouble shooting section to test the coil. VOM reads everything the manual says it should. Of course I could have done the test wrong.
Is there a better place to start my trouble shooting?
· Benwill1
80's toys
speaking of basics....is the distributor rotor spinning?? I broke a chain one time. You should have 12volts on one side of the coil, the igniter(electronic ignition) breaks the negative side of the coil to produce a spark. Hope that helps.
1 - 8 of 8 Posts
