Hey guys, I tried asking on a different forum but no luck on a fix.
If I'm at a stop light in neutral and try to put in in first it's hard to do that. I have to use some force. If I'm driving slowly and downshift into 1st sometimes it will go in fine but not always.
With 4th gear it also requires a bit of force to put in gear wipe driving but not always.
The truck has 160k miles and I just got it dlso I don't know anything about it really.
I bought a Lce short shifter kit since it included a shifter bushing and the small cup on the end of the shifter. It's made for a 88+ but since the bolt pattern on the spacer is the same I wanted to try it.
I installed the kit with the included white seat bushing but I could not put it in any gear so I ordered a red bushing and I could only put it in 1st, 3rd and 5th. I re-installed the original worn seat bushing and I can put it back in any gear but still have the 1st and 4th gear problem.
I've installed a new slave cylinder and my clutch master cylinder kept the clutch pedal rock hard when I pinched the rubber clutch hose by the slave cylinder. I've even messed with the length on clutch rod that connects to the clutch pedal.
The clutch bracket does not have any cracks BTW. I think it's the original clutch.
So what do you guys think It can be?
I don't want to put more cash into this truck if the Trans is going out
