Hello Everyone,
I own an 87 Camry 5spd. Awhile back, after running her very low on fuel, she started running rough under acceleration, a major loss of power and would want to die if given too much throttle. She would run fine on mostly level ground using only the slightest press of the gas pedal, but hills were a nightmare creeping along in first. She also started stalling out when first driving and wouldn't fire up again until I got a jump, then she would be fine, except with the loss of power. I then checked and set my timing to 10 degrees BTC. It was slightly off. Also did the cap/wires and rotor at this time. No change. The next day she was running considerably better, so I just figured the injector cleaner I put in, in case it was clogged injectors, had simply done it's work finally. I had power back, but had started having a "rattle" if given too much throttle or if I got close to the top of a gear. Then one day about a month ago, she stalled out on me and hasn't fired up since. So I got a Chilton's and started digging into what could be wrong. I'm at a loss and I'm down to a couple components that can't be tested. She occasionally tries to fire, but usually right when you are done cranking. After the coil was replaced, she tried a lil more to fire up, but only with the distributor turned counter-clockwise all the way. Fully advanced? Not sure. The motor is getting fuel and I have spark. I'll list what I've checked and/or replaced.
Compression test - good, 140, 145, 130, 128
Ignition coil - Replaced, old one had a crack although it tested good.
Cap/wires and rotor - Replaced.
Plugs - replaced.
Valve timing - good.
MAF sensor - good, I believe, Chilton's and a pic I saw here on the forums both say that the VC-E2 resistance should be 3k - 7k for the 3SFE, 200 - 400 for the 2VZ-FE. Mine comes in at about 280, as did 4 others in the junkyard. Thinking those values are backwards.
Ignitor - Not testable, Replaced with unit from the junkyard.
ECU - Not testable, plan to replace with a unit from the junkyard.
Oh yeah, I tested the TPS and
So that is the majority of what I've done so far to no avail. Also, the throttle body was removed and thoroughly cleaned. A good friend works as a tech for Toyota and he is leaning towards the ECU at this time. I came across a couple threads here that describe my exact situation, but no solution was ever posted. I was originally looking in the fuel system for the issue, thinking clogged injectors or fuel filter. Replaced the filter, pump is working because the plugs are wet after trying to get her started for a min. Plugs are also properly gapped. I think that is everything, my brain is fried having spent the last week banging my head against this problem.
Any ideas would be appreciated. It seems I'm at the point where I just have to start throwing new components at it until it's fixed, and that sucks, super bad.
Thank you in advance,
KorunRaa
Plugs - replaced.
KorunRaa
