My 87 camry 2.0 is not putting out any heat. Replaced thermostat and temperature control sensor, does anyone have any ideas. Thanks in advance.
Definitely need more info. To expand on this, if it is an LE (push-button controls), the solder joints on the control panel PCBs can go bad, which leaves you without heat. Try pulling it out and re-soldering all the connections (at the temp slider, cables between boards, etc.). Mine does it when the weather is really cold (like, below freezing - the perfect time for it to fail...)Is this an LE?
I installed a new heater control valve and yes it does have hot water on both sides and i also flushed the heater core.Is the hose going to and from the heater control valve hot on both sides?
Do you have water flow thru the heater core?
YesIs this an LE?
