1 - 5 of 5 Posts
1987 Cressida
Help a brotha out...pls...
I got a 1987 Cressida...was auto but jus recently swapd a 5speed in my baby.thats wer d problem starts...well only one or two problem...cant start it..
tranny i believe is R154,jus switched the bell housing...everything s good then i measured the drive shaft n i dunno wer to go from there...i dunno f theres a way i can find another shaft from other supras or jus get a one piece drive shaft but damn thts expensive..haha..tryin not to go tht route thts y.
ok so everything s on,jus not the driveshft..so I tried starting the car..didnt start..not aware of any wire im suppose to connect,thought it should start rite up,but it didnt=(...
so if any one can help me out that'll be great havent been goin to work cuz i got no ride...i need to get it runnin real soon...thanks in advance for who ever can help me out...
Cressida nut
91 Pickup (Hilux)2wd
Seriously there's this remarkable invention called a SEARCH button. you might want to check it out. As for what trans it is, did you get it out of a turbo or non-turbo supra?
Summary of what it will find you:
starting: you need to run the neutral start switch wiring from the trans to the pedal or bypass it.
Driveshaft: you should have gotten the driveshaft along with the transmission, then you wouldn't have had this problem. 1pc in a X73 BLOWS because you have to either lift the engine or drop the rear cradle to get it in and out.
1987 Cressida
Sorry bout that im new here...im not yet familiar wit TN forums...im pretty much exploring it rite now..wel anywayss...
ok..so the neutral switch is connected on d trans rite? which is on d driver side...so wat i do s connect that wire to the pedal?
how do you by pass that f i wanted to?which one s easier n which one would u prefer?
how bout the reverse lite wire?wer do i locate that?
thanks!!!
1987 Cressida
Tranny s NA,my bad forgot to include that...
1987 Cressida
Can anyone extend this information for me....thanks...
1 - 5 of 5 Posts
