Yesterday morning I drove to work, went to accelerate onto the highway and got nothing- it was like the engine stopped, no power at all, but it didn't shut off, after I let down on the gas it continued to idle, I was able to get right off the highway and drive on the slower roads well enough.
Problem I would guess is something in the fuel delivery, it is intermittent and seems to get worse when it is cold outside. I can sometimes get tons of power, great acceleration, but other times it chokes and I get nothing. Has never been as bad as it was yesterday though.
I had replaced the spark plugs and distributor cap/rotor last year in an attempt to fix this same issue (which seemed to help at the time) but now it obviously is something else.
I have read up on Jim Hopkins' posts (over at the Yahoo Cressida group) about EFI and the fuel filter issue, so at this point I am thinking most likely it is a vacuum problem somehow causing the system to not provide enough pressure or fuel when it is supposed to.
Any thoughts on this? I have not dealt with fuel lines before and feel slightly out of my league on that. Almost bought a new fuel pump but then saw you need to drop the whole tank to replace it. Is it a hard job?
Also read how the fuel pump sends a constant volume of gas regardless of the throttle position, so I am thinking since it idles fine and generally accelerates fine that the fuel pump is OK, not sure how to proceed.
Any suggestions?
Thanks,
-Mike
Any suggestions?
Thanks,
-Mike
