First post but lots of reading and I thank everyone for their contributions. Vehicle is a 1987 P/U 2wd M/T 22R (carburetor-Aisan #35291) 330K miles but about 7K on motor. Having a couple of problems, rough idle, truck bucking going down the road and the fuel will not stay in the bowl of the carb overnight. Rebuilt carb in Jan. and truck was running good. Started loosing fuel in bowl about month later but was still getting 23mpg so didn’t think much of it. Kept a check on oil for fuel smell but I got none. Then about 3 weeks ago the truck all the sudden started going dead when you would push in clutch after running down interstate or driving at the same speed for a couple of miles. Things I have done:droped fuel tank-clean as a pin inside, changed fuel filter, new fuel pump, added clear inline filter between pump and carb, rebuilt carb(second time), check timing, re-torque intake, head, and exhaust, checked valve clearance, compression check (178- 183psi), checked plugs and gap, new dist cap, checked air gap of signal rotor and pickup, checked all vacuum hoses, new air filter, changed oil, cleaned inside EGR vacuum modulator(above EGR valve) this seamed to help the going dead part when pushing in clutch. Checked the Emission Control Mod (gray box inside truck) with no broken solder joints also changed out with one from junk yard –no change. Removed the fuel cut solenoid tested ok and cleaned. Choke plate works great (passenger side) but the plate on the driver side remains almost closed all the time. And when you give it gas it tries to close (this seams odd to me or is this how it works). Now my problem is when going down the road it bucks when holding the accelerator in the same place as to maintain speed. It does not hesitate on acceleration. The fuel level (when idling) in the bowl is in the middle of the sight window. Rough idle-it will stay at about 800rpm if you rev it up it only comes down to 950-1100 and stays for a minute or five and all the sudden drop to 680-850 it varies. When idling at 750 I see no drops of fuel falling inside carb but if it is idled high I see them. Plus sometimes the idle will surge up and down.
Sorry for the long post, just wanted to give as much info as I could.
