Hello, new guy posting, original owner of a '89 22re manual p/u 2x4 w/180k miles. Have water temp. gauge issue spiking towards high range close to the red zone on turns, going down a loop ramp, and sometimes when the vehicle just started. And then it would go back down to a normal range. It is erratic at times then goes back to normal. No physical overheating from engine compartment, coolant and oil are within limits.
In the past, already changed the thermostat x2, radiator, radiator cap, fan clutch.
I also reset the plug on the water temp gauge sender (sensor on the EFI manifold attached to engine block). Anyone have this kind of problem before?
