1 - 2 of 2 Posts
Hello ppl,
this is my first post here, so any help is appreciated.
Due to extreme fogging, I have to replace my passenger side headlight assembly.
Now I removed the side marker and the front grill and removed the 4 bolts connecting the mounting bracket to the body. this frees the bracket from the body, and I can jiggle it around but not free it from within the cavity. The headlight assembly is connected to the bracket by a spring, 2 screws and a third alignment screw.
Am I doing this wrong? any help in this regard is really appreciated. I really cannot afford a body shop right now. (as you see I drive an 89 camry )
thanks
Jack
Not so Noob now!
You will need to remove the top header panel, that is the piece that sits in front of your hood. should be held on by 8 or 10 bolts. Also your grille is cliped to the headlight assembly and you will most likely need to remove that also.
1 - 2 of 2 Posts
