I've put some parts and time into the GF's Camry and haven't made any headway. It's an '89 Camry DLX, 4 cylinder FWD electronic automatic. The car has 238,000 miles on it.
Earlier symptoms were poor gas mileage (15 MPG) and no low end power.
I've done the following:
Cleaned throttle body and IAC
Replaced air filter
Cleaned EGR system
Replaced spark plugs, plug wires, distributor cap and rotor
Replaced fuel filter
Set timing to 10* BTDC with diagnosis port wires jumped (timing read in spec after removing jumper)
Checked compression (170 to 175 PSI across all four cylinders)
Verified cam timing was correct
Pulled engine codes: code 11.
From my searching, code 11 was an electrical supply issue to the ECU, probably caused by the old wiring to the alternator:
I pulled the EFI fuse, started the car and ran it through the gears when it was parked and read codes again: got the all-clear code.
Symptoms are still no low-end power. Once you get the revs up to, say, 2,000 to 3,000 RPMs and above, it pulls as hard as it should. I should buy a cheap tach to hook up for diagnosis purposes.
I'm a bit confused as to what it could be now. I do not recall the exhaust smelling overly rich but I haven't specifically checked. Also, the spark plugs I pulled out looked as if the fuel mixture was just fine.
What's next on my list is to check the cold start switch, oxygen sensor, engine coolant temp sensor and check for clogged exhaust/catalytic converter filter. I do not believe it's a vacuum leak due to how smoothly the car runs. No misses or hesitation, just no low-end power.
Any other thoughts?
Replaced air filter
Cleaned EGR system
Any other thoughts?
