1 - 5 of 5 Posts
Car stalls with acceleration. I put on a new AFM and still get the same thing. Someone told me the engine may not be creating enough vacuum to pull the flapper open. I can open the flapper manually whil giving it gas and the engine rund fine. but when i let go of the flapper the flapper closes a little and it acts like it is starved for air, then dies.
Could the problem lie in the egr or anything else?
The battery has died and the Alternator appears to be dead now also. Could the AFM not be getting enough juic from a jump start?
Thanks
· 96 3MZ M/T
Camry
well it could be your alternator if that seems not to be good. also yes your egr can be causing problems. also check and make sure that all vaccume line are on good.
· 3s-gte in a Camry?!?
'89 Camry Alltrac
Don't forget to check your ignition system... It sounds like you might have a weak coil.
-Charlie
1 - 5 of 5 Posts
