1 - 13 of 13 Posts
I wanted to give the internet a (mostly) comprehensive list of what all is required. Hint: it's more than you'd probably think for a swap between two engines of the same family.
Here's a short list of everything you need:
  • 2ZZ-GE, has to have the cable throttle.
    The '03 and later Celica GTS has drive by wire. You'll have to swap the throttle body with one that's cable-operated on one of those.
  • C60 or C64 transmission.
    There's some discrepancy as to what's best for shifter cable placement, because my setup is far from ideal. I'm not sure if the layout of the C60 (Celica/Corolla/Matrix/Vibe) is different from the C64 (Elise/Exige and Non-US 2ZZ cars). Probably is.
  • MWR engine mount bracket.
    MWR-705201 on their website, under the MR2 2ZZ swap section.
  • An aftermarket/custom intake.
    An SRI for the 8th gen Corolla should work, possibly with a different coupling to the throttle body.
  • Custom exhaust header.
    Either starting with one of the MR2 2ZZ swap headers or welding the 2ZZ flange onto the 1ZZ header like I did. Any standard 2ZZ header goes down at a ~35 degree angle instead of a 90 degree angle. This doesn't work unless you want to move the steering rack and cut a hole in the firewall.
  • Passenger side CV axle from a 7th-gen Celica GTS, ABS ring removed.
    If you have ABS and want to keep it, you'll need custom axles.
  • Driver side CV axle from a 6th-gen Celica ST (automatic transmission).
  • Flexible radiator hose for upper hose, stock hose doesn't work.
Electrical:
  • An appropriate 2ZZ-GE ECU.
    An ECU from an 00-02 Celica GTS is the most ideal US-spec ECU, pretty much entirely because there's a couple of aftermarket ECUs for the car. You can also get an ECU From a Corolla RunX Z Aero or Corolla Sportivo. All other 2ZZ ECUs use different ECU connectors and pinouts, as far as I'm aware, which would make it more difficult.
  • A wiring harness from an 00-02 Corolla.
    Getting one that had a 4-speed automatic is ideal, because you can use some extra wires from the transmission connector for the VVL valve and pressure sensor. Also, it plugs right into the aforementioned ECUs with minimal modification.
I've been extremely lucky to have access to AllData through my school. Without that, it would have been much harder to get all the wiring diagrams I needed. The Haynes manual is absolutely useless for 8th-gen Corollas. Doesn't even include the PCM wiring for the 4 speed automatic.
I've uploaded PDFs of the wiring diagrams I have here. If anyone needs any other diagrams, just ask and I can probably get them.
Total cost:
I'd estimate at around $3k to $4k, if you do the work yourself and depending on where you get the motor/transmission and what tools you already have. At least half of that is the motor/transmission.
I've dropped quite a bit more on this swap because I had almost no tools when I started, made a lot of mistakes (due to my own stubbornness and lack of resources), and replaced almost (if not) every single wear item on the car.
Edit: Unfortunately, my build is and forever will be undocumented because I took no pictures of the process (not that it would show much anyway) and the car has since been destroyed.
Anyway to print this thread off? I have an 01 Corolla S i'm looking to swap. Have a 2ZZ from an 04 Vibe GT along with the wiring harness for the engine to the ecu, trans, axles, ecu, and mounts.
hey i got the same project like you 01 corolla s manual and vibe gt 04 2zz with harness and ecu. how far are you on that project? what harness are you using and ecu? im stock with the harness i dont know if i can use a manual version of my 01 corolla or if have to be the automatic version. ca you give a hand or anybody
· Administrator
マズダスピード3
Per the op, the automatic wire harness has extra wiring to use for the ECU. This is for vvl and pressure sensors.
but why i would buy another extra harness [automatic] if a can get those vvl and pressure sensor wires from the 2zz harness that i have? the question is if a use the 00 celica ecu i can just plug and play my 1zz harness and add in the vvl and presure sensor wires?
I wanted to give the internet a (mostly) comprehensive list of what all is required. Hint: it's more than you'd probably think for a swap between two engines of the same family. Here's a short list of everything you need:
  • 2ZZ-GE, has to have the cable throttle. The '03 and later Celica GTS has drive by wire. You'll have to swap the throttle body with one that's cable-operated on one of those.
  • C60 or C64 transmission. There's some discrepancy as to what's best for shifter cable placement, because my setup is far from ideal. I'm not sure if the layout of the C60 (Celica/Corolla/Matrix/Vibe) is different from the C64 (Elise/Exige and Non-US 2ZZ cars). Probably is.
  • MWR engine mount bracket. MWR-705201 on their website, under the MR2 2ZZ swap section.
  • An aftermarket/custom intake. An SRI for the 8th gen Corolla should work, possibly with a different coupling to the throttle body.
  • Custom exhaust header. Either starting with one of the MR2 2ZZ swap headers or welding the 2ZZ flange onto the 1ZZ header like I did. Any standard 2ZZ header goes down at a ~35 degree angle instead of a 90 degree angle. This doesn't work unless you want to move the steering rack and cut a hole in the firewall.
  • Passenger side CV axle from a 7th-gen Celica GTS, ABS ring removed. If you have ABS and want to keep it, you'll need custom axles.
Electrical:
  • An appropriate 2ZZ-GE ECU. An ECU from an 00-02 Celica GTS is the most ideal US-spec ECU, pretty much entirely because there's a couple of aftermarket ECUs for the car. You can also get an ECU From a Corolla RunX Z Aero or Corolla Sportivo. All other 2ZZ ECUs use different ECU connectors and pinouts, as far as I'm aware, which would make it more difficult.
  • A wiring harness from an 00-02 Corolla. Getting one that had a 4-speed automatic is ideal, because you can use some extra wires from the transmission connector for the VVL valve and pressure sensor. Also, it plugs right into the aforementioned ECUs with minimal modification.
I've been extremely lucky to have access to AllData through my school. Without that, it would have been much harder to get all the wiring diagrams I needed. The Haynes manual is absolutely useless for 8th-gen Corollas. Doesn't even include the PCM wiring for the 4 speed automatic. I've uploaded PDFs of the wiring diagrams I have here. If anyone needs any other diagrams, just ask and I can probably get them. Total cost: I'd estimate at around $3k to $4k, if you do the work yourself and depending on where you get the motor/transmission and what tools you already have. At least half of that is the motor/transmission. I've dropped quite a bit more on this swap because I had almost no tools when I started, made a lot of mistakes (due to my own stubbornness and lack of resources), and replaced almost (if not) every single wear item on the car. Edit: Unfortunately, my build is and forever will be undocumented because I took no pictures of the process (not that it would show much anyway) and the car has since been destroyed.
Im curently looking to swap my 99 corolla, its an automatic. I curently own a C60 from a matrix, with axle shaft and shifter cable assembly with the shifter itself. The plan is to put the c60 and then do a swap in a few years, time to plan this all and get what i need. My question is about those axles shaft, i have been told that they fit directly on my corolla, not sure right now if i need to track the one you have mention... also, the wiring dont seem to hard to do but i am looking to do a racecar out that Racing Rolla, probably heading toward a high rev setup. In that case, am i better with a custom ecu or sticking with a 00-02 celica ecu Will give me enought tune ability? Thanks for the list btw! (Sorry for my bad english i am french canadian )
2002 Chevrolet Prizm 1zzfe 5spd
I have a whole c60 swap parts list everything I have is compiled from a thread on another website that I will link documenting/listing parts from Stillrolla i think and for sure Milky’s swap
That’s the thread , it should have everything
My parts list
Organism Font Darkness Brand Photo caption
there is a whole bunch of shenanigans about ABS and an intermittent shaft that I didn’t really care about maybe that’s a mistake but it’s all in the thread enjoy :)
1 - 13 of 13 Posts
