1 - 4 of 4 Posts
Is there a way I can recharge my A/C myself? I noticed a little nipple stickng out of an A/C line and figured that was the spot. Is there a product I can buy to recharge this in my garage instead of spending the money to have someone do it for me? Thanks, J
Grenaded piston
Your Camry uses R12, which you can't buy unless you have a license.
You can use Freeze 12 which is a replacement for R12 or convert to R134a (need a conversion kit).
If you got a 134 refrigerant, Yes you can do it yourself if you are mechanically inclined.
I got reload kits at major dept stores and auto stores. It has instructions and you can not do it wrong since the connectors fit only the right way. Just read the instructions.
Good luck
1 - 4 of 4 Posts
