1 - 5 of 5 Posts
Hey All,
I have a '90 Celica and am having some problems right now. I need to replace the wheel bearings but does anyone know in the front drivers' side but there is a hub that sits inside them - I do not know the name of this piece so I'm having trouble ordering it or finding it anywhere actually? Can anyone help me out?
· JUST RE ENGINEER IT
98 Prizum
its made this way, the big thing everything bolts to is the steering knuckle, the round thing with flat ends is the bearing and the thing that presses into the hole in the bearing with the studs in it is called a hub, you get all that put together and when you put it on the car the drive axle slides into the hole in the center and a huge nut goes on the end and make it real tight, now what part do you need?
1 - 5 of 5 Posts
