1 - 4 of 4 Posts
Proud owner of 1990 V6 wagon. Yesterday went on a long drive, got to my destination and the fan motors did not stop running. Any suggestions on how to fix?......thanks
Q
Guest
Check the fuse. If there is an open circuit, the system is designed to run
the fans by default. Keeps the thing from overheating incase something
goes wrong.
D
Guest
There should be a relay either close or in the high-amp fuse box under the
hood. It is porbably stuck closed causing the fans to run constantly. A less
likely possibility is the temperature sender is sending a constant hot
signal to ECM, it is the one with two wires.
HTH, davidj92
1 - 4 of 4 Posts
About this Discussion
2 Participants
davidj92
Toyota Nation Forum
Full Forum Listing
